JD G Cam Grind
48JD G
02-21-2006 06:16:34
Any recommendations on a good place to send my stock JD G cam to get a good competition performance grind? I have a 1948 JD G that I use exclusively for tractor pulling. The tractor is currently bored .125 over and fitted with High Compression Aluminum Pistons from Hinrichs Repair. The head (Cyclone) has been completely rebuilt with stock size valves and it has been shaved .050. I have a Jerry's Pulling Manifold and a Hot Mag. I also run the "Super 51 Pulling" carburetor from Robert’s Carb Repair. The governor has been completely rebuilt and I'm running the stock rods and crank with stock stroke. Any help or advice would be greatly appreciated. I need to decide if I should keep going bigger or sell before I’m completely broke.
Miller49G
02-21-2006 11:22:12
 Re: JD G Cam Grind in reply to 48JD G, 02-21-2006 06:16:34
Your set up sounds like mine. I have a cam from Robert"s in my 49" G. I"m still getting it together I hope it will run in the next few months.
RedJD
02-21-2006 08:42:33
Bullet Racing Cams 662-893-5670
HOSEMAN
02-21-2006 08:20:39
I HAVE A ROBERTS CAMSHAFT OUT OF A G THAT HAS LITTLE USE AND DECIDED TO GO A LITTLE BIGGER CUBIC INCH. CELL IS 616 437 4302
JDBert
02-21-2006 06:48:07
Berry cam service-
320-395-2377 or
www.berrycam.com/index.htm
