JD PTO
birddog
02-25-2006 11:59:46
How much HP can be run through the JD live PTO without breakage or slippage. The PTO was recently rebuilt and seems to be in good shape. The thing that concerns me is that the input shaft in the rear housing is only about 1 inch in diameter...that looks to be the weakest link to me. I suppose I could try it myself and see what happens,but maybe someone could offer some useful input on this first. The tractor is fresh and it's time to start tuning on the dyno. It's a 861 cube 70. Thanks
buickanddeere
02-25-2006 19:12:39
 Re: JD PTO in reply to birddog, 02-25-2006 11:59:46
Running 540rpm or lugged down and pounding?
birddog
02-25-2006 19:48:00
 Re: JD PTO in reply to buickanddeere, 02-25-2006 19:12:39
Ilike to make most tuning adjustments at 540 loaded, but no, I wouldn't want to try pulling it under 540, and that would be just long enough to get a reading. Dyno's are the best tool for tuning, but I've tuned enough tractors this way and know enough not to get carried away.
buickanddeere
02-26-2006 18:02:23
 Re: JD PTO in reply to birddog, 02-25-2006 19:48:00
Depending on the past 50+ years of use and abuse? You maybe able to get about double the rated HP for a little while. On a smooth steady load like a dyno she may slip the clutch packs before a shaft twists off.
