to jd b puller
52 G
02-26-2006 17:38:29
Rotated the cam one notch and came out 6 degrees closer. Did'nt want the suspence to get you.
Drew
02-27-2006 18:13:52
 Re: to jd b puller in reply to 52 G, 02-26-2006 17:38:29
I cant even figure out how you can possibly come to that conclusion; if there is infact 29 teeth on the crank gear and 58 on the cam gear. For each 6* the cam moves, the crank moves 12*. And what you are worried about is how much the crank moves.
I wish I could figure out a way to post screen shots of CAD drawings so I could draw it up to show how it works.
jd b puller
02-27-2006 16:37:36
Whewwww!!!! I can finally sleep again...
I might still be crazy, just not about this...
