h head
brandonf
03-01-2006 21:04:17
hey what are you guys using for valve springs for the h's I got a set of stockers and they only 60 on the open and 30 max on the close. I think we found some off of a 2.2 4cy that will get us 120 and 60 which is more or less where we need to be sooo the big ? is what are you all using because the stockers are pretty crappy
thanks brandon, I learned alot on this rebuild lotsa parts kinda bummed the deck height is different on every piston and my rods were up to 18 thou off on center line, but we got those ones fixed. Also has anyone ever built up the counterbore and then milled it out?
thanks brandon
