Only .100 Thick at bottom of cylinder bore!
BlastUm
03-10-2006 12:42:49
I have a MM that I had bored out big. The cylinder wall is only .100 inch thick at the bottom! Will the piston go through the wall eventually?
G/MAN
03-11-2006 07:43:20
 Re: Only .100 Thick at bottom of cylinder bore! in reply to BlastUm, 03-10-2006 12:42:49
What is "at the bottom"? Better to have a thin spot down low in the hole than up top where the pressures in the cylinder are at their highest. I'm not an pulling engine guru, but I think it's pretty unlikely the piston will ever go "through the wall". The main thing to worry about is the cylinder wall flexing and distorting and affecting the ring seal.
King Case
03-11-2006 06:17:07
I have a Case that is thinner than that. But i hard blocked it about 3 to 4 inches in the bottom for the side push of the piston. It has run a year and have had no trouble.
AC
03-10-2006 16:22:58
Whats BIG ???
BlastUm
03-10-2006 23:12:09
 Re: Only .100 Thick at bottom of cylinder bore! in reply to AC, 03-10-2006 16:22:58
5.5" in 800 Block
LW
03-11-2006 13:53:39
 Re: Only .100 Thick at bottom of cylinder bore! in reply to BlastUm, 03-10-2006 23:12:09
There are alot of variables here, If its a virgin never been sleeved HD 800 block you could go plow with it like that,A light piston would sure help, If you are going with a lot of stroke 7.5 or so you could pull the pin low enough to cause alot of stress, What rod and stroke combo? In the water jacket you have more like a .200 wall, It usually takes a pass of 5.900 to break through the cyl in a HD block on one side so I wouldn't worry.
BlastUm
03-11-2006 21:20:00
 Re: Only .100 Thick at bottom of cylinder bore! in reply to LW, 03-11-2006 13:53:39
It is stock 6 inch stroke with a stock steel rod. I did not plan to put any hard block in it. Thanks for all the replys, by the way!
AC
03-11-2006 04:22:31
OOOOOKKKKK , THATS getting BIG! I'd definately hard block some of it, maybe even 2/3rds up.
Jerry Cent. Mi.
03-10-2006 12:49:06
Might be wise to fill the block.
