JD 60 HEAD WILL IT FIT
CAT988
03-11-2006 20:49:03
WILL THE HEAD OFF A JD 60 FIT A LATE MODEL JD A????? ???
arll NY
03-12-2006 15:00:20
 Re: JD 60 HEAD WILL IT FIT in reply to CAT988, 03-11-2006 20:49:03
The 60 head will bolt on, however you will have to use the 60 intake & exhaust manifolds & the duplex carb.
Drew
03-11-2006 21:01:50
It will bolt right on. You will have to modify your carb linkage to fit the 2 barrel.
