wc won't start
buford
03-16-2006 18:30:42
we have been working on our wc for some time and have finally got her ready to fire up,shucks it will not start`we put in a 45crank, new rods d17 cam worked the head built the carb. used ac aluminum pistons w/new rings, time is ok,fireing on all cyls. compression is lower than I hoped for we are at 100 lbs++ where have we missed?? thanks for any info we are stumped!!!
Two Tone
03-17-2006 10:46:57
 Re: wc won't start in reply to buford, 03-16-2006 18:30:42
Double check the cam timeing and the valve lash. This could cause the low cylinder pressure and also not fire the plugs at the right time.
