4 1/16 piston's for DC case
merl
03-24-2002 20:39:59
does any one know where to find 4 1/16 piston's for DC Case
SEAMO
03-26-2002 21:12:23
 Re: 4 1/16 piston's for DC case in reply to merl, 03-24-2002 20:39:59
Try 1 800-247 2167 Herschel--Adams they are handling the distribution of the old M&W piston line. They were going to bring back some of the old applications.My old M&W book shows part number SP108 COMP. RATIO 6.7 HP is 52.5 284 cu. in..I also have writen in the book part #AP-8-S 1965 price sheet list at $76.10 a set. They took over I think after POWER SEAL had to give up the M&W PISTON name and M&W took the piston line back. I stand to be corrected on this. But I think that is what happend. SEAMO
Mark
04-03-2002 12:53:23
 Re: Re: 4 1/16 piston's for DC case in reply to SEAMO, 03-26-2002 21:12:23
This is great information!!! I had the same question about a month ago and was told then that it may be easier to get a JD 4020 kit and machine the sleeves to fit the DC block. I was told you could get this done (machining included) for about the same price as what a M&W kit would cost and the JD kit is easy to come by compared to the M&W kit. For what it's worth, I was also told that if you wanted to get radical with the DC, get a JD 5020 kit (4 3/4 inch pistons) and bore the DC block out to accept the larger sleeves and she'd run like a raped ape.
Just wanted to pass along the info I was given... but I'm sure going to call the number SEAMO gave to see if I can get a set of M&W's for one of the DC-4's I'm building. Thanks, SEAMO!!
