North Brook Antique Tractor Pull
Black Widow Pul
04-13-2006 07:28:01
Pull is April /15/ 2006 No Rain Dates! 4:00 pm Start time.. dont be late! No one can be signed up after 4:00.
We are located in Vale, North Carolina. 3 miles off of Hwy 18 on Hwy 10 on the left. We pull Antique Stock classes 2700 thru 12200. 500lbs incriments to 9200 then 1000 lbs incriments to 12200. 13.6 tires 2700-3700, 14.9 tires 4200-5200, 16.9 tires 5700-7700 18.4 tires 8200-9200, 20.8 tires 10200, 23.1 tires 11200-12200. NO ALTERED TIRES! We pull a 3.5 mph stock class (all classes) and a Fast 5 mph classes in the 4200, 5200, 6200, 7200. Factory High RPM"s 50 RPM override allowed. Must have wheelie bars with pads no wheels allowed. Drawbars must be ridgid in all directions 18 inches from center of rear axel, 20 inches high. A 3 inch floating clevis, No D rings if you use a D ring we will add a clevis. 7 dollars a hook, 2 to 3 hooks depending on number of tractors. If you have any questions about anything E- Mail me.
BlackWidowPuller@hotmail.com
THANKS!
PULLERNC
04-13-2006 19:01:14
 Re: North Brook Antique Tractor Pull in reply to Black Widow Puller, 04-13-2006 07:28:01
WHAT BRAND OF TRACTOR DOES WELL 4200,4200 5,4700. MAY COME UP ON SAT AND GET A TRY .
THANKS. P.S. WHAT BRAND IS A BLACK WIDOW
Black Widow Puller
04-14-2006 16:37:28
 Re: North Brook Antique Tractor Pull in reply to PULLERNC, 04-13-2006 19:01:14
The Black Widow, is a Allis WD. As far as a tractor that does well .... You never know. We pull everything AC, JD, Farmall, Min Moline as long as it is a Pre 1960 with the right size tires.
