wc allis clutch sliping
acwc
04-18-2006 16:55:19
My clutch started sliping on my wc, all new parts and no oil on them. I dont think my pressure plate is close enough to the friction disc. does anyone know the distance from the friction disc surface to the pressure plate mounting surface? thanks
Joe Skinner
04-23-2006 05:09:50
 Re: wc allis clutch sliping in reply to acwc, 04-18-2006 16:55:19
If you had the flywheel turned down they need to turn the same distance off the pressure plate mounting surface. You would be surprized how many people don't think about that when they turn the flywheels. As for the distance i'll try to see when I split mine or see if I have a flywheel here to measure for you. joe
allis boy
04-22-2006 10:57:54
ARE YOU USING THE 9 SPRING WD45 PRESSURE PLATE? I AM STILL USING 6 SPRING ON MY WD AND IT SLIPS TOO!!!
slowsmoke
04-18-2006 17:43:25
Book says there should be 1/4" between fingers and T.O. bearing. hope this helps!
