504 case diesel head on 504 diesel MM
1155puller
04-30-2006 20:47:40
I know that i have read on this site that bolting a 504 case direct injection head onto a 504 MM "Lanova" style head is something that has been done, and I was wondering if anyone had an idea as to how much modification had to be done to the case heads to fit on the minnie. how close are the holes to lining up? close enough to where a little work with the di-grinder would make them work? any help is appreciated. Thanks
Phil Munson NY
05-03-2006 10:50:57
 Re: 504 case diesel head on 504 diesel MM in reply to 1155puller, 04-30-2006 20:47:40
Don't know any specifics, but I would try the direct inj head from a MM 585 first; probably easier. best Yeoman
Captainhookerus
05-01-2006 17:08:58
You look at a Case head then if you figure out how to make it work let me know.
