JD. A cam
720 billy
05-10-2006 17:54:41
i need a cam for a 38 A. it has a power block and heisler head . the head had alot of work done to it what would work best thank billy
j.d. lover
05-12-2006 18:08:41
 Re: JD. A cam in reply to 720 billy, 05-10-2006 17:54:41
personally,I wouldn't buy a cam off the shelf.You need to degree your cam to see what your valve timing is;(ours was very tardy on the intake side)then I would send yours in to be built up and reground to the proper lift,duration and timing.It definetely helps out if you have the motor.
JDBert
05-11-2006 20:31:19
I've got a "Roberts pulling cam" from Roberts carb shop, in my 51'"A" thats coming out because I dont have enough motor for it. Drop me a line if your interested.
DSK
05-11-2006 18:16:16
Contact Berry Cam, 320-395-2377. They will provide a grind that is based on your motors cubic inches, compression ratio, and RPM. They have been grinding pulling cams for years and have a excellent reputaion.
