Pull Goldendale, WA June 4th
bdpayne
05-29-2006 20:22:56
Goldendale, WA June 4th at The County Fair Grounds. Wiegh-in starts at 9:00 Pull Starts at Noon. We pull two sleds one 6000 lbs the other one is 38000 lbs. Every thing pulls garden tractors, ATV"s, 2 and 4 wheel drive PU,and tractors old and new. Contact Brad 509-261-1150
newpuller
05-30-2006 12:32:40
 Re: Pull Goldendale, WA June 4th in reply to bdpayne, 05-29-2006 20:22:56
Where is Goldendale? I'm in Oak Harbor Wa.
bdpayne
05-31-2006 03:56:45
 Re: Pull Goldendale, WA June 4th in reply to newpuller, 05-30-2006 12:32:40
South central about 2 hrs east of Vancover.
Brad
JakeF
05-29-2006 21:17:03
Dad and I are hoping to make it if we don't have hay to bale by then. Will it be the same rules as at Wasco or will there be a 3 mph class also. Thanks
bdpayne
05-30-2006 03:50:47
 Re: Pull Goldendale, WA June 4th in reply to JakeF, 05-29-2006 21:17:03
Yep we are doing 3 mph in lighter classes.
Same rules as Wasco hopefully not as windy.
Brad
JakeF
05-31-2006 22:56:57
 Re: Pull Goldendale, WA June 4th in reply to bdpayne, 05-30-2006 03:50:47
Did you pull at wasco, and if so what. Dad and I were there and he pulled a 460 and I pulled a Super M. Jake
ndpayne
06-01-2006 08:09:11
 Re: Pull Goldendale, WA June 4th in reply to JakeF, 05-31-2006 22:56:57
I was at Wasco but couldn't pull Tractors were still hooked on hay equipment. Baled this morning so will have them all at Goldendale. I am the one with the 3020 JD powered with the Ford V8. Hope to see you there.
Brad
