wd45 drawbar advice
champ40
05-31-2006 22:38:42
i recently started pulling two wd45's in a stock antique class. i'm having trouble hooking up. i need some advice on setting up my drawbar. club rules state it has to be at 17" in height. it can go in or out or be modified so there's a 3inch hole for the hook. any suggestions?? thanks.
Krouthead
06-01-2006 03:49:30
 Re: wd45 drawbar advice in reply to champ40, 05-31-2006 22:38:42
Make a drawbar from flat steel connect at to the factory quick connect under the tractor,put a loop on the end of the flat steel (drawbar), at the legal distance from rear end. Use a frame under the bar with the adjustment of your choice, The forward hookup is a definite help.
Out Of Hiding
Krout
