When is the Marion, MI Fair Pull?
2 Cylinder
06-03-2006 16:25:05
Does anyone know when the Marion Fair Farmstock Tractorpull is? Also what classes will be pulled along with tires sizes and hitch dimensions. Any information would be appreciated.
Marion Vintage Power
06-04-2006 14:58:13
 Re: When is the Marion, MI Fair Pull? in reply to 2 Cylinder, 06-03-2006 16:25:05
The Marion Fair Farm Stock Pull is June 12 at 6PM
Classes are 2500# No tires bigger than 12.4x24 2700# no tires bigger than 32" 3500#-- no tire limit 4500#-- '' 5500#-- '' 6500#-- '' 7500#-- ''
20 inch high hitch with a 3 inch opening not less than 24 inches from center of rear axle.
?2
06-04-2006 16:54:27
 Re: When is the Marion, MI Fair Pull? in reply to Marion Vintage Power, 06-04-2006 14:58:13
what kind of rules?
06-11-2006 14:09:00
 Re: When is the Marion, MI Fair Pull? in reply to ?2, 06-04-2006 16:54:27
20" high hitch with a 3" opening for hook,
Rear weights cannot exceed rear radius a tire,
Front weights no more than 18" from front most point of tractor,
No johnson bars or vertical clevises,
tractor no more than 8 feet wide (scale width),
Tires may be cut on top of bar only, no cutting in front of bar or into casing.
