New to pulling
Case E Jones
06-04-2006 16:11:59
New (never done it before) and don't know what to expect from a Case VA. Most local winners are Olivers. What about gear choice, weights and locations, hitches etc. Any and all feedback appreciated.
Thanks
Lamont
06-04-2006 21:17:17
 Re: New to pulling in reply to Case E Jones, 06-04-2006 16:11:59
Get your hitch as high and as short as the rules allow. You probably won't need weight on the front unless you add a large amount to the rear. You'll just have to use trial and error on that. A lot of that depends on how well your tires hook up to the track. These little tractors are pretty high-geared in 1st, so I would start there on the gear choice. Your tractor may seem like it has plenty of power to go in 2nd, but you'll probably learn as most people do, it's a whole new story when you hook its butt to the sled. #1 priority is have fun. Happy pulling.
Jay in MN
06-04-2006 20:26:19
this is my third year pulling so I am still learning lots. As I was always told weights depends on tracks. I have found cant go wrong with wheel weights. our hitch height is 20". Keep your hitch in ( shortest possible ). I have pulled barely making a weight class, not much fun when I was worring if I had to many fumes in the gas tank. When it comes down to it, watch the guys you are pulling against, you will learn the most by trail and error. Also I have always used low gear, I feel I am at a pull not a drag race.
