Need good motor
656
06-24-2006 09:19:57
Looking for a good running motor around 100 HP that will bolt right in to 656. Has 282D in it now but needs work. Would like to actually compete in non-turbo 7000 lb class. Any help on turning the inj pump up or any other mods greatly appreciated!
D boll
06-26-2006 05:47:56
 Re: Need good motor in reply to 656, 06-24-2006 09:19:57
Do you have a stock block rule? I saw a 560 with a 354 perkins, good engine, cheap and fit in real nice non-turbo is 100hp AND NO GLOWPLUGS!
ejr-IA.
06-24-2006 11:25:43
A 715 301 combine engine will bolt right in that would be close to 100hp.Or you can pull the sleeves out of the 282 and buy 301 pistons in std. 30 and 60 over.A pump off a 806 disel will fit right on in place of your pump or put a larger head on your's.Idealy a motor out of a 766 360cid or 666 312cid. would be better yet.
