Oliver 88 wheels,,
ChadS
07-02-2006 11:33:27
Did 88's come with pressed steel from the factory?
BUDD
07-03-2006 04:00:19
 Re: Oliver 88 wheels,, in reply to ChadS, 07-02-2006 11:33:27
Chad;
If this guy wants to pull again with that set up he needs to bring the documents (parts book) that show these wheels were indeed an option for that tractor.
BUDD
ChadS
07-03-2006 07:27:43
 Re: Oliver 88 wheels,, in reply to BUDD, 07-03-2006 04:00:19
I'm sure he would if he wanted to,, If he was Dq'ed for that in the light Farm stock class,,, and he pulled in the other classes,, was he DQ'ed in the other classes he pulled in,, or just the light class? We dug up our old operators manual for our 77 we had years back,, book was for the 77's and the 88's, has a paragraph in it that tells it had both cast, and dish wheels. Should just allow pressed steel on all of em,, end the controversy,,,,, To me, its only a matter of time,, seeing how our farm stock classes have evolved since suitcase weights are now allowed. Thats just my opinion,,, I appreciate the club letting me exhibition pull my 460H! Thanks! See ya soon. Chad
A.P.
07-02-2006 17:42:24
You could order the Olivers with cast or pressed steel on either the front and/or the rear. This applies to 66, 77 88 Fleetline"s and Super"s. This is supported by factoy literature, parts books, etc.
Cody
07-02-2006 16:59:19
Yes, you could get a 66,77,or88 with cast or pressed rims fromt the factory. I have an original sales ad that will proves it.
770
07-02-2006 15:18:08
Yes, some 88's came factory with pressed steel wheels.
Clarence Barenie
07-02-2006 12:31:50
Tractor came out on cast wheels, Sorry about your luck ! Thats a visual item, just like top cut tires. !
Start paying attention !
If you knew an individual dressed his tires, would you protest him, before or after he beat ya ?
ChadS
07-03-2006 07:09:46
 Re: Oliver 88 wheels,, in reply to Clarence Barenie, 07-02-2006 12:31:50
Nobody's running cuts,, they are road worn!! ROAD WORN!!! LMAO! Chad
supermpuller
07-02-2006 14:30:50
Some 88's came with press steel, its time to let top cut tires in, just don't touch the front edge,that would end of problem of dressed tires.
