Stroker M
AntiqueOutlaw
07-03-2006 14:36:49
What is the max. stroke that I can put in my M while still running about 4000 RPM's. Any info. would be helpful. Thanks.
Gary Suckstorf
07-03-2006 21:05:51
 Re: Stroker M in reply to AntiqueOutlaw, 07-03-2006 14:36:49
drew where can you get a steel flywheel?
Drew
07-03-2006 16:02:50
You ARE running a steel flywheel, right??
I would want to make sure the rods and pistons are as light as possible. With even a stock stroke, piston speeds will be high and place an increased load on the rod bolts. Good rod bolts are a must!!
