well the cam being moved forward or back one space
bigdeere6565
07-22-2006 15:25:46
well moving the came forward or back wards one space help or not, was just playing in the grage with the cam since i broke the gear last weekend and had replaced it and was just wounding if this would increase horse power or degrease it,
DSK
07-23-2006 05:22:43
 Re: well the cam being moved forward or back one s in reply to bigdeere6565, 07-22-2006 15:25:46
Are you running the stock cam or a performance grind? Little will be gained by changing the timing on the stock camshaft. If however you are running a reworked cam with more duration, you will benefit from degreeing in the cam according to the grinders specs. To do the job right, you will need a degree wheel and a dial indicator. You will then set the cam to it's new lobe center spec. provided by the grinder. See archives.
bigdeere6565
07-23-2006 10:17:48
 Re: well the cam being moved forward or back one s in reply to DSK, 07-23-2006 05:22:43
it has a 630 cam in right now, was just playing with the cam friday in the tractor, befor i put the govener back on, thanks for your help,
Custom King
07-22-2006 18:20:14
Advance for rpms retard for low end.
bigdeere6565
07-22-2006 19:05:09
 Re: well the cam being moved forward or back one s in reply to Custom King, 07-22-2006 18:20:14
would like more info on this, tecnical advice , so standing on the flwheel side would you turn it clockwise or counter clock wise, if i move the came one space clock wise it changes the comp stroke bye 1 .750 back when the intake valve closes on the comp stroke,
