Need help for first time pulling with a JD 3020D
Bill Tremel
07-31-2006 11:49:41
Hello,
My son (age 4) wanted to see his dad pull our JD 3020D at the local fair this year. Since I never pulled before, I had some questions about pulling a stock JD.
1.) What common classes will the JD 3020D pull in.
2.) What gears are best to pull in each class. I noticed that there are speed limitations for various classes.
3.) What does a 3020D Weight with 38x15.5 rear's loaded with Calcium. I also have 2 stock weights on each rear and 5 stock front weights. The tractor also has a factory roll bar (no canope).
I don't plan on being very compeditive, but I just want to have a little fun. Any help and advise is greatly apprciated.
john dear
08-04-2006 22:31:36
 Re: Need help for first time pulling with a JD 302 in reply to Bill Tremel, 07-31-2006 11:49:41
I have a 3020D. No front weights, no wheel weights, no water in tires it is 8500 lbs. You will add nearly 2,000 lbs with water/calcium, 300 lbs worth of wheel weights and nearly 500 up front. Good chance you will be too heavy for the 10,500 class. Stick with low gear at that weight.
Jerry @ Pullsite..com
08-01-2006 13:03:57
In the early 70's, I pulled a '71 3020 Diesel w/SycroRange trans, 12-lug cast wheels & 15.5's, but not loaded. Everything else stayed on, inc. 3pt. hitch. Replaced the factory wide front with a non Roll-a-Matic narrow front & 7.5L X 15 tires. With 2-150# weights hanging on the 3pt. crossbar, I was right at 8000#. With the wide front on, I don't think I could have made the class, unless the 3pt was removed. My guess is that you might be close to 9500#. I checked Firestone's site for chloride loading - you can find it here.
Without any pump work, that tractor dyno'd 75hp. Considering the weight you might be pulling at, I think 3rd gear might be too high, think 2nd would be better. But that's my opinion...You got to get your feet wet somewhere, & you don't know what it'll do till you try. Have fun & good luck...
chuck D
07-31-2006 18:30:40
I"d say it would weigh around 9000 lbs with everything you have on it. In any class for your first time I think third gear would be a good choice. There is obviously weight to be lost on your tractor if you really have to, but if you"re just out for fun - big deal, pull in a 10000 lb class if you wish! Good Luck!
