powerblock
ajdeereman
07-31-2006 19:51:48
I have a powerblock on my 1953 JD 60 can anybody tell me any specs like how far over bore and compression and what it should have foe power the rest is stock.
Kevin
08-01-2006 19:50:21
 Re: powerblock in reply to ajdeereman, 07-31-2006 19:51:48
My JD 60 is totaly stock tired and original with a powerblock installed by the dealer when it was new. With alot of blowby i am seeing 55hp. Me and my builder are looking for 75hp when we rebuild it. Stock it has a 6" bore and we are going to 6-1/8" bore with extensive head work. We are running a carb from a 70 to deliver more fuel to the bigger bore.
Drew
08-02-2006 10:06:53
 Re: powerblock in reply to Kevin, 08-01-2006 19:50:21
Is this 75hp w/ a stock cam or a regrind? I hope you can get that much, since Im working on building a simular engine, but I think 75hp w/ a stock crank is being awfully optimistic.
mjjk
08-02-2006 18:50:41
 Re: powerblock in reply to Drew, 08-02-2006 10:06:53
the cam is a reground by berrys, it also has bigger valves in the heistler head
buickanddeere
08-02-2006 09:55:23
Carb on 60 and 70 are 100% identical except for the metering orfice sizes. Air flow is identical. Roberts Carb has a list of the all-fuel and gasoline nozzels etc to mix and match. Odds are the 70's stock metering will run lean. You will have to weld an O2 sensor bung into the exhaust and read with a wide range O2 sensor to really know the ratio.
mjjk
08-01-2006 19:44:42
I have a jd A with a powerblock, 6.125 pistons, heisler head and stock crank and it puts out about 68 hsp, very good runner with very little investment. By the way, I have the pistons for sale if anyone is interested.
Topeka
08-01-2006 19:51:43
 Re: powerblock in reply to mjjk, 08-01-2006 19:44:42
what is the price tag
mr.thinker
07-31-2006 19:59:21
sure steped up to the plate there osk, oh thats right the question wasn't about pedel tractor's
mr.thinker
07-31-2006 19:56:45
pb is 1/2 biger than stock, if it hasn't been bored any?(6 inch)around 45 hp??
oskpuller
07-31-2006 19:56:07
aske one of the thinkers
Been there Done that
07-31-2006 19:56:01
6.125 is fairly easy,compression is your choicr ie. rods,piston design etc 55-60 hp. is possible given the facts,RPM also factors in.
