more power
80kid
08-07-2006 18:59:32
i am 16 years old and i want more power out of an John deere 80 any ideas i need for a local pull this saterday... (tire pressure(18.4/34), things like that plz help
the tractor is weighing 10,000 lbs and pushes at least 70 HP but i am getting beat by a R and 830 i wanna win like all of you help me plz
Motorken
12-06-2006 09:44:56
 Re: more power in reply to 80kid , 08-07-2006 18:59:32
You didn't say if they were outhorsing you, or if you were spinning out.18.4-34 generally seem to do better than the 23x26 that you find. Worn tires generally better. 8-11LBS tire pressure-about 9seems good. 23 degree generally better that 45 degree tires.The R is about 7-8 inches longer in the front end which gives it a small advantage over the 80-830's. The R's final ratio is about .25MPH slower as well, but it is a 50hp tractor and should start struggling hp wise around 10k and up. Check your fuel filters and if you can get someone to check your transfer pump pressure do that. Get someone to show you how to turn up your rack a little or a lot. Add weights or water to the rear tires and between flywheel and rear axle. Most 80-830 will be front heavy, so plan on no more than 1-2 weights up there if needed. Also, set a good example by adding a set of wheelie bars...your big tractor may not really need them, but when you start winning others will watch you and know you play safe...Good Luck
