stroker rods B JD
720 billy
08-11-2006 20:33:33
if you stroke a crank. do you need a longer rod if so how do you gauge your length. will a 7.5 stroke work good in a B and will it be reliable. thanks billy
B-maniac
08-12-2006 20:08:48
 Re: stroker rods B JD in reply to 720 billy, 08-11-2006 20:33:33
You will either need a shorter rod or a shorter piston or it will stick out of the bore the amount that you lengthened the crank throw. You are a lot better off if you use a shorter piston or one with the wrist pin closer to the top to offset the stroke diff. A shorter rod will put a lot more side pressure on the piston which will cause more drag,heat and wear. The only reason to use a short rod would be for clearance reasons. Also, once you have a larger air pump,you have to figure out how to feed it to reallize the highest gains.Good Luck
jd b puller
08-12-2006 06:41:58
Yep, you need different rods, different pistons, and yes, 7.5" is easy. my e-mail is open.
