Ideas to make 4010 lighter??????
4010 pLLER
08-19-2006 05:54:00
Tractor weighs 6780 lbs. with driver on. Would like to shed about 400-500 lbs. Rock Shaft has been removed, press steel wheels on back, narrow roll-o-matic on front. Any ideas on how to make tractor lighter would be appreciated. Anyone know where I could find a narrow front without the roll-o-matic?
jus tryin
08-28-2006 17:52:39
 Re: Ideas to make 4010 lighter?????? in reply to 4010 pLLER, 08-19-2006 05:54:00
I have a swartz front end off a 4010 Iam stripping down, Also try pulling the pto out.
I also have a m and w aluminum oil pan 4 sale
JDGnut
08-21-2006 18:11:55
Get rid of that heavy steering motor, and steering valve.. build a wide front.. and either manual steering it with a rack.. or Use hydrostic steering.. and steering cylinders... JDGnut
find a peg wheel
08-21-2006 11:47:46
find a peg wheel off a two cylinder JD tractor, they hold up pretty darn good and are still fairly light....they ususallly can be used up to ~9000 lbs
John179
08-21-2006 07:48:32
make your own seat mount, factory one is heavy. make your own floor board factory steel one is heavy as well. remove hydralics, pto. make a custom aluminum radiator. or even use a car rad.
Dairy Farmer
08-20-2006 20:11:45
i'd say to take some of the little stuff off like aircleaner bowl, mabe take the fenders offput a smaller air cleaner on it and just eliminate the little stuff that you don't need.
