best way to stroke 88 oliver
Blake G
08-21-2006 22:21:19
Im tired of losing, so im gonna put some time and money into my 88, ive heard alot about stroking, whats the best combo, thats affordable and reliable, like how much stroke and what rods abd psitons, would prefer to use existing rods if possible, but not manditory, im staying verying open minded...thanks
Crutch
08-25-2006 08:12:26
 Re: best way to stroke 88 oliver in reply to Blake G , 08-21-2006 22:21:19
Here are a couple ideas you can consider.
1100 massey head, also known as a 99 head I believe. They work well and can be worked with a lot. 4.5 inch bores can be done but you need a solid block to do that (hard block). I think in your case I would go with a more reasonable bore and keep it cool. You can also make the stock head work if you wanted to have it massaged by someone that knew what they were doing. My opinion, go with the largest valve without shrouding them. Off center grinding the crank gets you a few more usable cubes but then I would deck the block and run 0 (zero) deck clearence. Persoanlly I would push it and run less than thirty thousands between the head and piston if you are going to run stock rpms but that might not be the smartest thing for you. I would want 250 on the compression. On the cam a good grinder should be able to set you up but you have to know every other detail first. The cam (IMHO) is the last decision to make. Once you have the short block figured work on the induction. If you have to keep the same manifold have it cut then you can open the runners, How much? That depends on the cubic inches. Then it has to be welded back together. The stock carb is to small if you raise the cubic inches. If you have to stay with the stock carb I would for sure go with a high compression ratio. These are just my opinions. The bottom line is do what you want and learn from your mistakes. The other guys also make good points about hooking the tractor up. That should not be taken lightly.
Video your pull then compare it to other somewhat equal tractors and see what the differances are.
B-maniac
08-23-2006 18:45:05
Blake, I think what they are all trying to tell you is, if you are running out of traction then save your money until you have that problem solved. If you are running in a "realistic" gear for the weight class and track and are still running out of power (assuming proper tuning) then go ahead and spend the money. Be advised,though,someone else will always have more money than you...I'm sure you get my drift.
buickanddeere
08-23-2006 18:23:58
Three most important ingredients to winning is traction, traction and traction. Look past the engines on the tractors that place 1st,2nd & 3rd. Have a look at the hitches, weight distribution and tires/tread/pressure.
Blake G
08-22-2006 20:31:59
I know only one guy can win and in farm stock...isnt stock, but ive heard alot of good things about 88's being one of the better tractors out there with lots of potential....so im just trying to find it....and ive been planning on this work for the last year, so i have the money...just need the knowledge of what works and what doesnt.....
jd b puller
08-22-2006 19:08:10
Blake, you're still gonna lose more than you win. Just the way it works. If you are having fun now, leave it alone. Or spend a bunch of money (and probably jump up a class) and be right back where you are now, just lighter in the wallet. Only 1 guy gets to win and everyone wants to...
JOE Zip
08-22-2006 07:49:54
What division ? Kind of makes a lot of difference what weight and division you are tring to pull in.
Blake G
08-22-2006 16:32:41
 Re: best way to stroke 88 oliver in reply to JOE Zip, 08-22-2006 07:49:54
im pulling 5000 and 6000 antique and farm stock
B BARENIE
08-22-2006 18:03:51
 Re: best way to stroke 88 oliver in reply to Blake G, 08-22-2006 16:32:41
Call Brad maybock (spelling) in Ohio !
he can sell you part's and or build a complete motor . Don't have his phone number !
He sometimes advertiizes in the Hook magazine !
Please remember, that very few are running stock in farm stock!
ChadS
08-23-2006 10:48:53
 Re: best way to stroke 88 oliver in reply to B BARENIE, 08-22-2006 18:03:51
Nope, not stock anymore! LMAO! Chad
D-Day
08-22-2006 20:45:17
Do you mean Brad from Maibach Tractor in Creston, Ohio? If you do, here's the info:
13701 Eby Road
Creston, Ohio 44217
(330)-939-4192
Toll Free: (800)-808-9934
Fax: (330)-939-4483
