Need Plugs with longer electro in JD G Power block
Ben.So.Tex
08-23-2006 18:49:40
What is a good plug with a longer electro that will work in my JD G Power Block? The others 386 and D21 are recessed in about 1/2 inch + from the Bore, I need a plug that will reach or be at the edge of the bore. Thanks Ben
TN PULLER
08-24-2006 12:59:50
 Re: Need Plugs with longer electro in JD G Power b in reply to Ben.So.Tex, 08-23-2006 18:49:40
Machine the D21 back so it will go deeper in your block more compression and will run better.
Jak
08-24-2006 06:37:44
3116 Autolites have a longer electrode.
jd b puller
08-23-2006 18:57:51
If they are the same as what fits in a B, then try some AC 88L, Napa is the best place to get them.
