Would like to invite you all to the pull. 2006 Morrow County Tractor Pull Sunday, September 3, 2006 6:30 p.m. at the Grandstand Adam Coleman (419) 295-4592Weight Classes In Order Of Run: Sled 1: 3500 4000 4500 5500 6500 7500 8500 Sled 2: 9000 9000 Open 10000 10000 Open 12500 12500 Open 14000 Sled 1 Prize Money 50% Payback Sled 2 Prize Money 1st - $100 2nd - $75 3rd - $50 4th - $30 5th- $20 8 or less will pay places 1-3 Hook fee: $20.00, No Double Entries Everyone pays at the gate. RULES: 1. All drivers must be at least 18 years old. 2. Only Gas, Diesel, and LP Factory Equipped tractors allowed. 3. No Funny Fuels, Nitrous, Alcohol, Water injection, or Propane Injection Allowed. 4. All tractors are to run the Suggested High Idle for their model with an allowed 20% over. 5. NO CUT or GROOMED Tires in any way, IF ALTERED NO HOOKING. 6. Any Rubber Tire Size Allowed, Radials Welcome, NO STEEL LUGS or Dual Wheels 7. Two wheel drive tractors only, however, front wheel assist can pull as long as 4WD is disengaged. 8. Drawbars are not to be shorter than 18 inches from center of axle to hitch point. 9. Drawbars are to be no higher than 20 inches from ground to top of hitch point other than 3500 & 4000 18 inch max height. 10. Hitches must be ridged in all directions. 11. No part of drawbar to be higher than hitch point. 12. Hitches must have a 3 inch opening and be made of at least 1 inch diameter material. 13. Clevises are allowed as long as they are a twisted type and comply with rule number 12. Except Open Classes 14. NO STRAIGHT CLEVISES ALLOWED. 15. Engines must be of stock appearance as well as cylinder block, heads, and manifolds. 16. Single fuel pumps and/or injectors, carburators of original manufacture and design ONLY. 17. NO AIRPLANE CARBS, military carbs or non agricultural carbs allowed! 18. All Classes on SLED 1 are 5 mph. 19. All Classes on SLED 2 are 7 mph other than Open Classes will have NO Speed Limit 20. Tractors entered in Any Open Classes CAN NOT run in any MPH classes. 21. Speed will be monitored on sled and all pullers will be allowed 2 beeps and the 3rd beep puller is D.Q.ed 22. Wheelie Bars are required in Open classes & recom mended for all other. 23. No weight allowed past 12 feet from center of rear axle to furthest point forward. 24. Rear weights are to be no further than 18 inches past furthest point of rear tires 25. Rear weights are not to obstruct hitching ease to sled. 26. Any loss of any object from tractor while hooked to the sled will result in a Disqualification. 27. Side shields allowed but must be easily removable. 28. All pullers pull at own risk to damages of their equipment. 29. Any or all damages are pullers responsibility not the promoters. 30. All tractors must weigh in before hooking to sled and once in staging area no changes maybe allowed without reweighing. 31. No Riders and a Safe speed will be enforced in the pit area. 32. Class Closed once the first puller of that class hooks to the sled. 33. All pulls will start with a tighten chain. NO JERKING OF THE SLED 34. Pullers must stay seated for the entire length of the pull, no bouncing in the seat. 35. Hands must be on steering wheel, throttle, hand clutch, and or hand brake for entire length of pull. 36. All drivers are allowed 2 tries to pass the 75 foot mark once past no restarting. 37. Puller must pass 50 feet to qualify for premium except for tie breakers or pull offs. 38. First puller of each class is the test puller with the option to drop and come back in 3rd position. 39. $500.00 protest fee with Protester’s tractor inspected first! 40. Judges and officials decisions are final... including situations not covered in these rules. 41. No Drugs or Alcohol allowed before or during the pull. 42. Each tractor will be given a visual safety check. Any fluid leaks or items that jeopardize safety will result in disqualification. 43. Drivers are to watch the flagman once tractor is hooked to sled. Flagman is in control. Failure to follow his direction will result in disqualification. 44. Tractor (not sled) must stay within boundries or be disqualified.
