Pulls near Cincinnati, Ohio
560IHFan
08-28-2006 16:04:19
Looking for any info on running sled pulls near the Cincinnati, Ohio area that do not use USAP rules? ie: Any year tractor ok, no MPH or RPM limit
6K to 8K: Farm Stock or Modified Stock (no turbo) would be great, thanks in advance
yellowandgreen
08-30-2006 06:15:10
 Re: Pulls near Cincinnati, Ohio in reply to 560IHFan, 08-28-2006 16:04:19
I am 99% sure it is non cut tires and we do not weight the driver. Sure hope you can make it we would like all the new tractors we can get. There is not a website but if you would like more info let me know on the website and I will give you my phone number.
560IHFan
08-30-2006 17:53:20
 Re: Pulls near Cincinnati, Ohio in reply to yellowandgreen, 08-30-2006 06:15:10
Seen the classes you are going to run in Greenup on pulloff.com. Are you planning to run the same 6000 classes in Augusta, KY, if so I'll bring both of my tractors. A phone number to get directions would be great.
yellowandgreen
08-28-2006 18:59:58
There is a pull friday night in Greenup County KY. Might be a little far depending upon where you are from. We have a little club that has a 2-3-4 cylinder with turbo or 6 cyl. natural 6000 pounds class, no rpm limit or speed limit. Also there is a pull in Augusta KY(About an hour south of Cinncy on the double A highway) on Sept. 16.
560IHFan
08-29-2006 17:57:49
 Re: Pulls near Cincinnati, Ohio in reply to yellowandgreen, 08-28-2006 18:59:58
Will have to pass on this Friday, but plan on going to the Augusta pull. Is there a website to get info about classes and times. Just have a few questions...like which tires I can use cut or not and how many weights to bring. Thanks in advance and hope you have a great pull on Friday night, I'll make it down there for one or your pulls..the 6000 (6cyl) is just what I am looking for.
