IH 450 puller needs help???
Brad Stiefvater
08-31-2006 09:51:49
My Dad pulls an IH 450 and has been doing so for about 4 years. He now wants to increase HP. Can you guys give me some pointers on overhaul kits to soup it up a bit. I have done many overhauls before so I do know my way around an engine. MY question is what pistons are best for this and witch ones can be used with an LP head if we actually find one. Also what kit could be used to get more HP if we use the original head. How much can one take off the original head to increase power.
Really just need advise on what works best to get the HP increase he is looking for
Thanks
Brad Stiefvater
Josh Caplinger
09-02-2006 15:47:41
 Re: IH 450 puller needs help??? in reply to Brad Stiefvater, 08-31-2006 09:51:49
Hey Brad. It is all in how much you want to spend and how much horse power you want. See you will be fine in milling your head and puting in big valves. You will get right at 60 horses. But if you want to go bigger let me know I know a guy that could set you up with as much power as you want. It's just going to cost you money.
TWL
08-31-2006 19:01:46
You may get lucky and get a little over 60hp by not stroking,but stroking is the only way to keep up with the competition(atleast in these parts)I have a 370 cubic inch M 100+ hp that I would sell if it would help.
Brad Stiefvater
09-01-2006 04:47:15
 Re: IH 450 puller needs help??? in reply to TWL, 08-31-2006 19:01:46
OK so where is a good place to purchase these stroker kits . Are we talking pistons/sleeves and crank?. What is the cost?
Are ther any options to help while still using the standard crank?? Like LP gas head and different pistons.
Thanks
Josh Caplinger
09-05-2006 10:26:30
 Re: IH 450 puller needs help??? in reply to Brad Stiefvater, 09-01-2006 04:47:15
How big you wanting to go? You can run 4 3/8 pistons right into the block with out geting into the water jackets. Any bigger than that you will have to put sleeves in it. With it being a 450 you can run a 7 inch crank. Or you can just put a 7 inch crank in plush new crank rods and you will get close to 85+. It all depend on how big you want to go. I know a guy that could help you but it will cost $$$$$. If you want his name and number I have his card.
ChadS
09-01-2006 07:42:09
What kind of pulling do you do? Low gear farm stock,, or ??? What weight, tire size, and hitch are you running? If your running low gear, stock hitch, (not fast hitch) if you go over 7000lbs alot and run those classes constantly, a stroker is the best way to go. You can get kits that lets you keep the 4-1/8th bore, so that can save you a few bucks. Keep the 450 gasser head! Those are good cyl heads, and you can modify them alot cheaper than buying a LP head, even if you find them for under 800$$!!! 75to85 hp in low gear, you would probably never have power problems with a stock hitch, with 14.9's, or 16.9's would be a good setup. So,, what's you got in mind? ChadS
Brad Stiefvater
09-01-2006 09:40:22
 Re: IH 450 puller needs help??? in reply to ChadS, 09-01-2006 07:42:09
my Dad is 82 and pulls in the stock farm tractor class .problem is the guys in his class 6500 Stock are all modifiying to a certian degree and still allowed in the stock class. He could move to the modifiy class if he had to.
I believe he just wants to crank it up a bit without getting to involved. What would be the best thing we could do without changeing the crank.
ChadS
09-01-2006 14:56:02
 Re: IH 450 puller needs help??? in reply to Brad Stiefvater, 09-01-2006 09:40:22
When is the last time its been overhauled? Get a compression guage, run a compression test. Remove the plugs and open the throttle up as far as you can when you crank it over. Record the results. If its under 150psi, think of pulling the head off, have it rebuilt, and if possible shave a bit off it to raise compression. .100 or less will make a difference. If the pistons are flat top style, look into a Tisco rebuild kit. If it has domed pistons in it already, if the sleeves look to be in good shape, clean it up and put the head back on, get it running, and recheck the compression. If you pick up 10 or more psi in the cyl pressure you will see a gain in power. Rebuild the distributor advance under the points plate, rejet the carb, and a stiffer governor spring will wake up a C-281. ChadS
Super Mta puller
09-01-2006 11:21:03
Keep your head.Mill only lighly. A good valve job stock no porting .Find someone who is a good aluminum welder and fillthe crater plus alittle on the dome.The deere guys do it all the time just wont admit it.New rings and a good hone job.200 psi compression willwake it up.Use ten percent ethanol pump gas.Have fun.ps a pertronix ign. and good plugs wont hurt.
SteveM
09-03-2006 16:58:56
 Re: IH 450 puller needs help??? in reply to Super Mta puller, 09-01-2006 11:21:03
Let's talk more about the aluminum welding. Can you be more specific ? Sounds interesting.
SUPER MTA PULLER
09-06-2006 11:13:25
 Re: IH 450 puller needs help??? in reply to SteveM, 09-03-2006 16:58:56
Fill up the crater and build up the dome to add compression.I have been told Schooler in Mo. does it for the jd guys .Thats all i know.
AGCO AVENGER
08-31-2006 15:28:25
Can you say STROKER????
