WD foot clutch
Bob Allis in Wi
09-08-2006 14:41:11
I burn"t out the clutch at a pull last night. I want one that will hold up to pulling. Any sugestions or peopl to buy from or not to.
AGCO AVENGER
09-08-2006 20:27:07
 Re: WD foot clutch in reply to Bob Allis in Wi, 09-08-2006 14:41:11
Call Fort Wayne Clutch. They can put metallic buttons on your clutch disc. They also have heavier springs for the pressure plate. I just burned mine out, put 6 buttons on each side to fix. Be sure you are using a 9 spring pressure plate. Stroker motors & 38" tires can use up a stock clutch pretty quick
Avenger
Jim Johnson
09-08-2006 19:48:18
You must not have had it adjusted right because we have one that is turning a lot of horses (over 200) and been running for years, never had a problem.
