RPM Tach for pulling
Blake G
09-12-2006 21:11:42
im looking for a rpm tach for my oliver 88, does anyone know where i can get one, plan on running 2000-2500 rpm so a 3000 rpm max tach would be perfect
Kurt @ Hamel Repair
09-17-2006 06:21:24
 Re: RPM Tach for pulling in reply to Blake G, 09-12-2006 21:11:42
Call 8-6 CDT and I'll fix you up.It is an Autometer tach that uses a probe to count flywheel teeth.Work very well but you have to mount the probe(sensor) and then it has to be callibrated with another tach.We set ours about 10 rpm above the tach used at NATPA pulls. Mon-Fri Ph. 308 493 5699
slowsmoke
09-13-2006 15:47:21
Try a marina (boat store) got a 3000 rpm tach that was waterproof
Blake G
09-13-2006 22:21:22
 Re: RPM Tach for pulling in reply to slowsmoke, 09-13-2006 15:47:21
do the boat ones hook in like any other tach?...the ones that i have seen are for the deisel boats
PGpower
09-12-2006 21:23:28
I installed a digital tach from ProSport Performance on my MM U. It was easy to install, just hook up to power, ground, and the coil and shows rpm accurately.
Overall I am satisified, but wish it was easier to see in the sun light. Numbers are not quite bright enough to see all the time on a bright day going down the track.
the following address show get you to there website. I got mine off of ebay.
http://www.prosportgauges.com/Prosport%20Digital%20Gauges.htm
casepuller1
09-14-2006 17:59:43
 Re: RPM Tach for pulling in reply to PGpower, 09-12-2006 21:23:28
I had a prosport gauge and sent it back. It bounced around to much and couldn't get a good reading, it would jump 500 rpms while idleing.
Glad yours works good for you, I will say they were good to deal with and told me to send it back for a full refund, now lets hope I get my money
papafoutz
09-15-2006 19:28:18
 Re: RPM Tach for pulling in reply to casepuller1, 09-14-2006 17:59:43
I called cyberdyne and they told me it won"t work on a 2 cyl. John Deere. And I was wondering if it work on a postive ground also. I guess they was wrong about that.
papafoutz
Drew
09-17-2006 18:35:51
 Re: RPM Tach for pulling in reply to papafoutz, 09-15-2006 19:28:18
Mine works great on a Deere, but is hooked to a MSD box. Whether that makes any difference or not, I dont know.
Drew
09-14-2006 20:13:06
I have a Cyberdyne digital tach on my Deere and it works great. Reads to 10rpm and doesnt bounce around at all. It checks dead nuts on the same to a photo tach or the kind that clips on a sparkplug wire.
