found a red diamond truck engine.
Andy2
09-20-2006 19:03:55
I found a red diamond truck engine. at a scrapyard today. Where do you find the size and model on these eninges? Is it worth getting.(it has a broken manifold, distributor and dented oil pan from being man handled)? Thanks
CASEPOWER
09-21-2006 08:25:29
 Re: found a red diamond truck engine. in reply to Andy2, 09-20-2006 19:03:55
There was a story on the Red Diamond engine in Old Power Pride, June/July 2006 issue. If you look between the air compressor and the block just below number 1 spark plug you will find the engine size and serial number. It is on the drivers side, not the pass side. The 406 also could have had a 2 barrel carb. I will be happy to post the article with pictures on the Old Power Pride site if you would like. Jonathan
Trkr
09-21-2006 07:00:57
I the manifolds still there,the 406 had a 1 bbl,the 450 a 2 bbl,the 501 had a 4 bbl.
Andy2
09-21-2006 08:03:00
 Re: found a red diamond truck engine. in reply to Trkr, 09-21-2006 07:00:57
The intake base is broke off. There is an IH stamp on the exhaust. The red paint is still on. Is this worth saving? Unfortunatly, nothing comes out of this yard cheap. Everything seems to be on it. It even has an air compressor mounted on the driver side.
Buzzman72
09-20-2006 21:53:57
If you're referring to an IHC Red Diamond, as in 372-406-450-501-etc, not sure about RD engines but IH usually stamped the engine size on a machined pad on the block on the passenger side of the engine, near or at the front, usually just below the head and just behind the water pump.
Not sure about external parts availability; that manifold might be a problem.
jmixigo
09-20-2006 20:57:20
If you mean a REO Diamond T, most of these used Continental or Hercules industrial engines(BIG 6 cylinder).The conti will have the engine series cast into the side of the block. The Herc should have a metal tag rivited to the block near the top. Both used one or two letters then three didgits signifieing the cubic inch displacement.
BDM
09-21-2006 06:24:17
 Re: found a red diamond truck engine. in reply to jmixigo, 09-20-2006 20:57:20
You'll find big time Diamons engine collectors here. Look through their archives also.
http://www.binderbulletin.org/forums/?
BDM
09-21-2006 06:24:47
 Re: found a red diamond truck engine. in reply to BDM, 09-21-2006 06:24:17
oooops, Diamond :-)
Cody
09-21-2006 10:43:58
 Re: found a red diamond truck engine. in reply to BDM, 09-21-2006 06:24:47
I have found 450's with 4 bbl manifolds on them. Alot of them don't have the size stamped on the ID pad, since they were dealer replacement blocks and were suppose to been marked by the dealer.
