palmersville tn pull
1066
09-21-2006 19:04:45
what are your farm stock rules.thank you
Jeff Oliver
09-22-2006 10:31:29
 Re: palmersville tn pull in reply to 1066, 09-21-2006 19:04:45
Those rules are for antiques. From your sig if you have a 1066 it is I think NTPA rules or something. Billy barler would know more about that one give him a holler at 731-364-5630. If you have an antique then what Jak said applies
Jak
09-22-2006 09:54:58
Farm Stock is:drawbar limit is 18 inches high,no weights hanging out past the front tires,3 and 1/2 mph, and no cut tires,rear tires need to be of the original size for that particular tractor.Super farm is 20 inches high with front brackets of 11 ft from the center of the rear axle including weights and no top cuts.
