Which manifold for a 4010 turbo addition?
4010 Pulr
10-20-2006 20:31:19
Which manifolds should I use for a bigger turbo on my 4010. I have the M & W turbo setup on it right now. Would like to put a bigger turbo setup on it but still keep it all under the hood. Any suggestions on manifold that would work the best? Manifolds off a 4320 or 4430? Any help would be appreciated.
1st a puller
10-21-2006 07:52:56
 Re: Which manifold for a 4010 turbo addition? in reply to 4010 Pulr, 10-20-2006 20:31:19
hey there, most people put a 4320 manifold on them. call central tractor in st. Johns, they should be able to fix you right up. seems as if they have changed hands and are called something else now. a 4430 will bolt on your 4010 head, so maybe look at them and see which one is designed better.
how'd your pullin season go this year anyways? your ol G still runnin good? got any BIG plans?..or get the 4010 bugs out first?
4010 Pulr
10-21-2006 19:54:43
 Re: Which manifold for a 4010 turbo addition? in reply to 1st a puller, 10-21-2006 07:52:56
My pulling season was pretty much a washout. Had a knee surgery the middle of May for a torn maniscus. Took a fall the day after surgery and completely undid the surgery and tore the ACL also. Had to wait till the middle of August for the 2nd surgery to give the swelling a chance to go down. The doctor just cleared me for work the first week of October. Pulled once at Remus in July with the 4010, finished last in 8000# class, then took 1st in the 9000# Class. The only other pull I made it to was Isabella County Fair. 4010 is running well, I just need more runs down the track to get the setup down. I will probably run with the Remus pulling Club more next year if they keep the 8 & 9000# farm classes. They are close to home and have good tracks to pull on at Remus and Blanchard. Would like to see them run an open farm class like they do up to Hawkins. They were saying that they need more tractors or they may do away with the farm classes. No big plans as money will not allow at this time, maybe just fine tune what we have for now.
