WHAT PISTONS IN WD PULLER???
CASEY
04-14-2002 12:53:03
I AM BUILDING A WD PULLER. USING A WD45 CRANK AND WD PISTONS. I WAS WONDERING WHAT PISTONS WOULD BE BEST TO USE TO GET MORE POWER. THANKS CASEY.
Ken
04-15-2002 19:03:06
 Re: WHAT PISTONS IN WD PULLER??? in reply to CASEY , 04-14-2002 12:53:03
Casey E-mail me and I wi;ll sell you one strong WD pulling motor. Ken Foland
Irv
04-14-2002 13:50:30
Go with Agco pistons for an Allis gas model 175.
This will give you a comp ratio of 8.25 to 1 if
you are using a WD-45 crank. I've used Tisco WD
pistons with a WD-45 crank, and I've used 175 Allis Power Crator piston with a WD-45 crank. I'll take the Allis Crator pistons anyday over an
after market flat piston.
Allis Puller
04-15-2002 03:36:44
 Re: Re: WHAT PISTONS IN WD PULLER??? in reply to Irv, 04-14-2002 13:50:30
I'm doing the same thing, have already bought everything, but did you have to go with a different carb?
casey
04-15-2002 18:56:55
 Re: Re: Re: WHAT PISTONS IN WD PULLER??? in reply to Allis Puller, 04-15-2002 03:36:44
i have the big carb for the wd. i just have to get pistons then i guess ill find out.
