JD cam upgrade?
Bassndeere
10-28-2006 18:55:10
Running a farm stock JD70LP. Planning a rebuild this winter. Will replacing cam with a 720/730LP upgrade my rebuild? Is there a gain in lift/duration? What are the spec's? What about replacing head with 720/730 LP head? Any gain there?
Thank you
buickanddeere
10-30-2006 20:25:44
 Re: JD cam upgrade? in reply to Bassndeere, 10-28-2006 18:55:10
Later G/70/720/730 all have the same lift and duration. A custom aftermarket re-grind is required.
Mike Aylward
10-31-2006 10:06:57
 Re: JD cam upgrade? in reply to buickanddeere, 10-30-2006 20:25:44
Glen, I agree that an aftermarket grind works better. However, the 720/730 cam is ground entirely differently from the late G/70 cam. Also, the lobe spacing is different as well. Just trying to clarify. Mike
bassndeere
10-31-2006 01:25:21
Thank you for the insight. Can you suggest a good aftermarket brand or machine shop? Don't want to go wild, stay dependable, but be competitive.
