what head to use?
770 Puller
10-29-2006 22:53:27
I'm building a 59' 770 with an 880 engine pushed as far as bottom end will go. Having trouble on head though. I have an LP head, machine shop thinks i should get em a stock head to destroy, they have to open up the chamber alot. Is there anyhting else that will fit an 88/880 block?cross flow perhaps? Any ideas greatly appreciated.
Eric Bloom
11-01-2006 03:29:51
 Re: what head to use? in reply to 770 Puller, 10-29-2006 22:53:27
just out of curiosity what will a 310 head flow?
thanks
ejr-IA.
10-30-2006 18:13:17
We used a 1600 head wiyh big block chevy valves.
88Power
10-30-2006 05:58:38
Best head to bolt to an 880 block is the GK195U/1100MF/S99 head. Chamber can go to 4.5 bore easily. 2.05 intake valve size. 250cfm at .600 lift with some work. Nice head and what the best 88's with 4 main blocks are running.
I've built a number of these heads and do have a couple castings if you can't find one. They are pricey though as they are tough to find anymore.
770 Puller
10-30-2006 23:02:48
 Re: what head to use? in reply to 88Power, 10-30-2006 05:58:38
whats the price on those heads? what can I get out of my 88 LP gas head? 1600 head do the trick? Im in over my head,lol
88Power
10-31-2006 06:36:45
 Re: what head to use? in reply to 770 Puller, 10-30-2006 23:02:48
The 1600 heads are not that great either. Only advantage over the 88 is the chamber size is smaller. An average 1600 head with 1 5/8 valves will flow 125cfm vs. 250 for a well-done GK195 head. If you want to be competitive go with the better head. Otherwise you will be a class filler.
770 puller
10-31-2006 08:55:19
 Re: what head to use? in reply to 88Power, 10-31-2006 06:36:45
what price range do these heads run? what casting numbers to look for? serial numbers? will S88 roller rockers fit them?
88Power
10-31-2006 10:32:57
 Re: what head to use? in reply to 770 puller, 10-31-2006 08:55:19
$750 to $1200 for bare casting.
2 different castings, a big 148cc chamber and a small 128cc chamber. Either one is good for flow, the smaller one will bump compression.
No SN break to worry about to my knowledge.
They will with modifications. Better option is either JD 4020 rockers or Murphys 1100MF.
770 Puller
11-01-2006 19:50:38
 Re: what head to use? in reply to 88Power, 10-31-2006 10:32:57
only thing i can find about 1100 gas is a distributor tune up kit in a magazine lol. HAd 2 places tell me they never made an 1100 gas. are these heads made by waukesha or continental?
