Farmall H
Chad C
10-30-2006 09:26:20
Simple question guys....what is the bore of a H farmall after the sleeves have been pulled. Will that take something like a super H piston? Do NOT want to bore, just want to run larger piston without the sleeves. Thanks
RichH
10-31-2006 11:34:44
 Re: Farmall H in reply to Chad C, 10-30-2006 09:26:20
Don't forget that you have to have some rings made to fill in the top grove where the sleeve sits. If you don't you will lower comprestion.
D Slater
10-30-2006 18:16:36
Can't remember what a H block is down to the thousand of inch but its real close to 3 9/16. Stock SH used 3 1/2 pistons original with thickwall sleeves. Thinwall sleeves and 3 9/16 pistons also sold for SH. The 300 C-169 engine used stock piston size 3 9/16 with thickwall sleeves. There was a serial # break on C 169 engine. Before break wrist pin size was same as your H. after break rods were changed to small wrist pin size. Also some of the fire crator and some other pistons had small wrist pin. Adapter bushings were sold for early rods to use small pin with those rods when using pistons with small pin. H,SH ,300 are all the same stroke.
D Slater
10-30-2006 18:23:33
 Re: Farmall H in reply to D Slater, 10-30-2006 18:16:36
Forgot to add, there is 3 5/8 pistons for 300 and 350 and were stock in 350. But you said you didn't want to bore.
606
10-30-2006 16:45:17
Will some one answer this question that knowes what they are talking about.Please
superh
10-30-2006 16:04:22
An M has a bore of 3 7/8. The sleeves will not fit into an h block. 350 pistons should fit after some honing(3 5/8).
Ken B
10-30-2006 12:20:06
Without sleevs the bore of a H block is 3 9/16. That is the same as a 560 only the rod pin placement is not right.
Chad C
10-30-2006 12:35:40
 Re: Farmall H in reply to Ken B, 10-30-2006 12:20:06
Thanks, isnt that the same bore as a super H also?
af
10-30-2006 09:37:33
just put super h sleeves in it or even m sleeves because its the same block... im pretty sure M sleeves will fit.
brandonf
10-30-2006 21:23:06
 Re: Farmall H in reply to af, 10-30-2006 09:37:33
I think there were some cat pistons that would work do a search it will pull up the answer for you, I think that is what I read on the thread
