WC Puller
9860marks
11-04-2006 13:19:54
O.K., I finally got me a WC allis and a WD-45 crank. I want to build a pulling tractor but I don't want to go the usual stock overbore kit. I want to try something really radical that has been proven. Any help in this area wound be greatly appreciated since I am new to this hobby.
mlpankey
11-04-2006 20:19:33
 Re: WC Puller in reply to 9860marks, 11-04-2006 13:19:54
crankshaft specialties in memphis stroke the crank . 4 5/8 bore arias pistons have to use custom sleeves from dardin . 2.100 intake valves 1.80 exhaust. port till they start to seap water then liquid glass the whole engine it helps with the sleaves to. or call barney taylor in ohio he,ll sell a complete 390 cube for around 8000. save you alot of leg work trying to figure out all the combinations. or machine a deck plate and get up around 500 cubes if no deckplates are aloud then stick several head gaskets epoxied together.its only money that stops how radical you can go.
