tire size
C Arms
11-09-2006 19:00:35
I need advice on tire size I have pulled in stock class the last year and a half and plan to pull in open class next year
I pull a WC allis with a D17 engine I am currently using 14.9 X 28 rear tires I have available either 18.4 X 34 or 18.4 X 38 for next year
Which would be the best size for my tractor
I will be pulling in 2nd gear with no restrictions on speed or rpm
I can easily turn 2200 rpm now and may make a few modifications this winter
I amm fairly new to pulling so I need the help of some of you veterans
Thanks
C Arms
11-09-2006 19:58:01
 Re: tire size in reply to C Arms, 11-09-2006 19:00:35
I know what you mean I can get in the 6 mph open class at 3750 & 4250 I pulled the 4250 last sat in 1st gear and finished 4th everybody else was in 2nd or 3rd gear
I have been pulling stock and breaking the 3.5 speed limit regularly so I would slow down and then lose all my power at the end
Even so I still finished 3rd in points in 4000 lb
and stayed in the top 3 - 5 all year
I think I have the power to trun the 34's but I'm not sure about the 38's
dave in MN
11-09-2006 19:42:13
My best friend pulls a wd with "e" motor, and I've been down the track acouple of time myself... just guessing, you will need 150+hp to be able to spin the 18.4X34 or 18.4X38 in 3rd or 4th gear. You will not have enough weight in the 4000-5500 classes to get tires to hook up so you will need alot of speed.
Good luck, the folks in the no rpm-speed limit classes are very good, experienced pullers. Be prepared to get educated!
15.5 X 38
11-10-2006 15:29:39
 Re: tire size in reply to dave in MN, 11-09-2006 19:42:13
Just by stepping up from the 28 inch tires to a 34 or 38" rimmed tire is one heck of a ground speed increase!! It may be tough in low gear, but doubt you go far with a stock D-17 engine in the WC to spin off a 18.4. Id keep looking for 34 or 38 inch rims,but try to find a smaller tire, like a 15.5 or a 14.9 if speed is needed, but wont be such a big tire to rob all your power!
Jak
11-10-2006 18:26:37
 Re: tire size in reply to 15.5 X 38, 11-10-2006 15:29:39
I ran across a set of Armstrong 12.4 38's the other day off a spray coup that were some kind of sharp and roadworn that would be perfect for a WD with a 12/13 inch wide wheel.Wouldn't you know it they weren't 14.9's or 15.5's what I was lookin for!
15.5X38
11-12-2006 09:48:39
 Re: tire size in reply to Jak, 11-10-2006 18:26:37
Thats still,, a big jump and its worth doing. I pull against a WD45 with 12.4's and it holds its own.
