rocker ratio
770 Puller
11-13-2006 00:09:06
anyome have an idea what ratio the rockers on a JD 4020 gas is? are the diesel the same?
88Power
11-13-2006 10:16:45
 Re: rocker ratio in reply to 770 Puller, 11-13-2006 00:09:06
JD rockers are 1.65:1. Dsl and gas are all the same. Putting them on an Oliver is easy, but the right way is to get a new shaft made. The JD rockers use a 0.749 shaft and the Oliver is 0.741. You can run them on the Oli shaft but they fit sloppy. Okay for low RPM, but problems if you spin it.
