welding cranks
36 A
11-18-2006 06:29:56
Has anybody ever welded a crank at home and had it ground else where.I can get an old a john deere A main case with the crank in it and thought about welding it with wire feed.The wire is like 7018 in stensel strenth and those cranks seem to be good iron.If i weld it in the mains to hold it from moving.I only would try like a 1" strok first that leeves 2" old crank think it would hold.Just a thought what do you think.
36 A
11-19-2006 19:35:30
 Re: welding cranks in reply to 36 A, 11-18-2006 06:29:56
I"m pretty sure i do but i"ll check that out.This is still a what if thing till i get some ??? asked.Thanks
stroker 88
11-18-2006 17:49:34
we use 10018 equivalent wire, don"t leave it in the crankcase, it will build up stresses. we preheat crank to about 500, weld, straighten while still real warm, let sit for a day or two,rough grind to about .100 from size, check straightness, let sit another day or two, get it as straight as possible, finish grind rod journals, then grind mains for final straightness. not saying this is the only way, but it seems to work for us.
36 A
11-18-2006 21:27:29
 Re: welding cranks in reply to stroker 88, 11-18-2006 17:49:34
we have a forge that it might fit in the top can a guy weld it right in there.How do you weld, all on one then the other or a little on both here and there?
stroker 88
11-19-2006 18:30:34
 Re: welding cranks in reply to 36 A, 11-18-2006 21:27:29
we don't have a forge. we just heat it slowly with a torch, try to get the heat even and soaked in, one journal at a time. thinking has a good question, do you have someone to do the grinding after you weld it?
thinking
11-19-2006 15:23:08
You might check to see if your crank grinder would grind it after someone else welded it.
