North Central Indiana rule changes?
AC
11-21-2006 18:25:30
So what exactly changed in the farmstock rules? you guys have some of the highest powered "stock" tractors I have ever seen! Still a good pull every time, though! Can I (in Farmstock) use a Le Roi replacement block in my WC? The mains, bore and stroke are the same as a regular WC block. There is very minor physical diference, but the dimentions are the same. I dont want to have to get another wc block, because mine is cracked. This is a direct replacement, not a "combine engine" or anything. Oh yeah, it was built the same time the WC was. Andrew
