big valves
460/560
11-28-2006 08:00:07
I"ve been thinking about putting some bigger valves in my 460. I"d like some opinions on this. Stems on the 460 are 3/8. Some bbchevy valves have 3/8 stems and I think they"d be long enough. I"d like to use the smaller 11/32 stems though. Would it be worth it. Also, how big can/should the valves be. Stock 301, 2400-3000 rpm range. Ideas would be appreciated. Thanks
460/560
12-01-2006 06:30:58
 Re: big valves in reply to 460/560, 11-28-2006 08:00:07
Thanks for the comments. I feel like the head can be greatly improved. It has a very tight short side radius and is very wide and flat. I would plan on some bowl work. I would think bigger valves would also help though. I realize that too big of a valve will kill velocity, but some thing a little bigger with a smaller stem would surely help. I"m also looking into different pistons to up the compression. The bigger valves would also increase comp. a little.
Jon Aller
11-30-2006 18:45:22
People are not usually keen on sharing secrets when it comes to pulling;-) My best advice is seek out a shop that rebuilds heads for racers and truck pullers. They will understand what you want to accomplish and help you build a head for the short block that you have.
Good luck.
thinking
11-30-2006 12:18:56
If you are running a stock bore/stroke/rpm range the valves are probably sized idealy. If you go large on the valves, velocity will be to slow thru the throat to promote good cylinder filling.
Some bowl cleanup on a stock cast head will almost always without question show good improvements.
460/560
11-30-2006 08:10:19
I guess none of my posts are worth anyone's time? Everytime I put something on here, no one will ever reply.
mlpankey
11-30-2006 19:38:35
 Re: big valves in reply to 460/560, 11-30-2006 08:10:19
the biggest intake valve you can fit then what ever size exhaust valve you have room for.if i had a busted head i would use it to experiment with to see where i could go with out getting into water. 2.100 int 1.80 exhust wolud be nice if it would fit not reall familiar with 301 like i am with 226. hope this helps youre post is always worth posting.
