New Years Resolutions
ChadS
12-13-2006 14:17:36
To put my 1940 Farmall H Modified back together. Repainting my JD green Farmall M back to red.
Repainting my wifes Super H.
Better tires on the M.
Building a new Super H for Mom to get back into pulling. Restore Dad's JD 730 gas back to original.
Clean out the shed for more room to work.
The 40 H is comming along. Changing the ring and pinion back to stock,,,, grinding the block for the stroker, just got the new pistons so I can now bore the block to what I need. Gotta still hard block it before I bore it,,,
Maybe a short list,, but will keep me out of trouble for a while. What do you guys got going on for next year??? dont have to be about pulling, or tractor related,,,, Later! ChadS
Jeff Oliver
12-13-2006 20:01:17
 Re: New Years Resolutions in reply to ChadS, 12-13-2006 14:17:36
Well since I pulled in Tunica I found out that if I go back I need to find some more motor in my 88 and Super M. Actually gonna just check and adjust everything on them as they are Farm Stockers.
Gotta get my 1800 put back together so I can use it this summer. Got a JD M in there that needs finishing also.
Honest puller
12-13-2006 17:44:20
I'll try not to cheat!! or maybe only cheat half the time! I just hate to lose..lol
dctom
12-13-2006 16:07:54
gonna take the stroked crank out of my DC and over bore it to 4 3/8 with stock crank have 45 more cubes than now think that will satisify the new teck boys??? lol
Barenie
12-13-2006 19:19:36
 Re: New Years Resolutions/dc once removed in reply to dctom, 12-13-2006 16:07:54
DC:
I remember, in Bremen in my last life time, not being able to start the boat, I remember a man who no's everything, allowing me to put an 8777 distilate head on my tractor. an spend 450.00 U.S.
currency to port and polish. I remember, rear wheels shuddering because the (m) was burned in a fire, and the brake drum springs needed to be replaced. I remember a farm stock john deere guy sneeking around my tractor before I pulled to measure hitch heigth ! Man was I green, I hope your legal, caus I work to hard, and I hate cheaters.
I'm bringing two jacks, 500.00 bucks, a chisel and some wrenches, because the old guards, and the old ways are history !
Just get tight !
I'll keep punching order's in !
I hate the cheaters !
And don't ever misinterpert the rules !
PASS IT ON !
Barenie
12-13-2006 18:00:49
 Re: New Years Resolutions in reply to dctom, 12-13-2006 16:07:54
A I did the math , with 4-1/16" x 5-1/2" you would be at 285.42 cubes. If we went 4-1/16" x 6.5
=337.10cci. If we went 4-1/16" x 7.5 = 388.96, then you would need a petcock in the bottom of your oil pan like red's red farm stocker !
So, better not push 250thds overbore because that might be disqualified as a suspect puller, if you hang to long at the back end of the track !
If we go together on some pistons, maybe we can get a better deal.
DC been tired of your long gears, for a long time, but you have been a heck of a puller, wait till the final rules come out, because there's got to be more to come !
I've got a 370ci m short block for sale in 2 months, paint it yellow and you'd be okay !
Wishing you and your's a safe and Marry Christmas.
Bud Barenie
P.S.
Don't hook well, because if we are all stock, nothing should hang.
So goes the bore !
ChadS
12-13-2006 16:36:15
Bout time you "freshened up" the ol DC!! Looked a liitle slow,,,,, HAHA! Chad
AC
12-13-2006 14:53:59
Finish My big H motor, put the one I took apart back together, get my W4 ring and pinion back ;) and see that Mopower actually gets his 65 horse MM R running. ( hey miracles happen , just sometimes takes time, like 7 years)
ChadS
12-13-2006 16:42:27
 Re: New Years Resolutions in reply to AC, 12-13-2006 14:53:59
That aint no kidding! How long have I been putting Wilder back together????? I have to take out the limited slip in the 40, so Im gonna have it apart to get them gears back to you. It will swap right in to the H now,, I set up the pinion to use the H bearings instead of the W4. Will be in touch when I get em ready. Chad
