What rim for 18.4 x 38's
4020 pllr
12-15-2006 20:26:53
How wide of a rim should I use for a set of 18 x 38 Armstrongs on a 4020? Pulling 6500-9000 lb. classes, stamp on the tire side wall recommends 16" rim. Would be interested in suggestions.
Matt Welbaum
12-16-2006 07:36:56
 Re: What rim for 18.4 x 38's in reply to 4020 pllr, 12-15-2006 20:26:53
I have a set of 18.4 on 24" and a set on 19" just depends on how tall you want the tire to stand the wider the rim the shorter the tire if you need more speed down the track use narrower rims.
jim storms
12-16-2006 03:54:42
the pulling club im in rule's says the rim cant be any wider then the tire.I have a 720 with 18/38's & a "R" with 18/26's both mounted on 18" rims... both look real good and I feel it's as good a foot print as I'm going to get, they both pull purty damn good too
JDH
12-16-2006 03:42:50
Kinda like Chevy Ford I guess. You can ask 5 pullers and probably get 5 different answers. I like one size bigger rim on a tire i.e. 18.4 tire, use a 20" rim. etc
Lamont
12-16-2006 06:31:47
 Re: What rim for 18.4 x 38's in reply to JDH, 12-16-2006 03:42:50
18.4s were intended to be mounted on 16 inch rims. One size bigger would be 18 inch.
JDH
12-16-2006 07:30:36
 Re: What rim for 18.4 x 38's in reply to Lamont, 12-16-2006 06:31:47
True, but I meant one bigger than the tire size like the example I gave. 18.4 on a 20" rim, 16.9 on a 18" rim.
Lamont
12-16-2006 09:02:28
 Re: What rim for 18.4 x 38's in reply to JDH, 12-16-2006 07:30:36
I see.
