are the M and 450 interchangeble
BAXTER
12-22-2006 10:53:16
I have an M tring to hop it up, some guys on here say to use like a 450 cam and manaflod and stuff from a 450 on an M. How much is interchanble, i dont want to buy some stuff from a 450 and then it wont fit. Will the cam fit, manaflod, and what do you think about a 450 carb?
MJF
12-22-2006 19:53:26
 Re: are the M and 450 interchangeble in reply to BAXTER, 12-22-2006 10:53:16
A 450 Cam will go right in and is a big improvement. M SM 400 450 manifols inerchange in fact if you buy a new manifold it's the same one for all 4. As far as a carb yeah it'll bolt right on too but Chad S says that the M carbs are better. Talk to him he has some good mods for the M carb to make them better than the 450 carb. If you want to go to a 450 bore 4 1/8" you will have to get the block bored to fit the sleeves. You however can get a 4" bore which is a SM and 400 bore. If you go that route you will not have to bore the block. M SM 400 450 Heads will all work but the 450 gas head is the best. If your M is an All-fuel head I'd look into a gas head for it, big improvement. Hope this helps.
BAXTER
12-22-2006 15:26:00
manifold* i no i splet it wrong but its just a little off..
buickanddeere
12-22-2006 14:29:56
Manaflod?
miracle child
12-22-2006 12:37:11
yes it will all bolt on with no problems and yea the 450 cam is the way to go
