Chad S
bm3501466
01-12-2007 15:16:59
Is the bell housing on the H the same size as the M? What frame rails will bolt to the H?
bm3501466
01-13-2007 16:50:24
 Re: Chad S in reply to bm3501466, 01-12-2007 15:16:59
What can I do to my 301 governor to make it run 3000 RPM?
ChadS
01-17-2007 09:58:05
 Re: Chad S in reply to bm3501466, 01-13-2007 16:50:24
Grind about half the weights off, readjust the linkage to pull just a tad harder on the governor rod, but not enough to make it idle too high. I do like the combine governor housing,,, its a single arm VS 2 arm, and its easier to rig up linkage to to turn up the rpms with a turnbuckle. Chad
ChadS
01-13-2007 10:16:04
460 rails bolt onto the H bellhousing. They widen out to the same width as a M though. Chad
mshultz
01-12-2007 15:36:08
No - won't bolt up.
ChadS - could you e-mail me about limited slip differentials? I've tried you, but no returns. Not sure if its getting through or not. mshultz@danville.k12.pa.us
Thanks.
ChadS
01-13-2007 11:36:44
 Re: Chad S in reply to mshultz, 01-12-2007 15:36:08
ChadS3@hotmail.com or www.thetractorshop.com
