help building a oliver 310 gas
adam schachtner
01-17-2007 14:29:14
what can i do to get more cubic inches out of this thing. I will be using stock crank email me with ideas and phone numder
A.P.
01-17-2007 15:59:16
 Re: help building a oliver 310 gas in reply to adam schachtner, 01-17-2007 14:29:14
A set of Darton sleeves say 4 3/8" bore. Machine block to fit. Bush small end of the rod down to automotive sized wrist pins. Custom pistons or a stock set with the right pin height - you may need to offset the bore in the bushing. Should give you right around 390 cubes.
